Come join us in Portland, TN! TCAT Portland (Nashville Satellite) will be hosting our Section’s Event on September 25th at 5:00 PM CST.
ASME Boiler and Pressure Vessel Code (B&PVC) inspector Duane Morrison will be our guest on September 25, at TCAT Portland (Nashville Satellite), 602 S Broadway, Portland, TN. Duane will be presenting and educating us on ASME (B&PVC) welding documentation.
Although welders are expected to follow the requirements found on Welding Procedure Specifications (WPS) and other welding documentation, code welding documentation is a subject that not enough of us in the welding industry understand. Come learn a little bit about it.
Duane is employed by Bureau Veritas, and performs inspections at the Lochinvar LLC facility in Lebanon, TN. Lochinvar builds thousands of ASME Code pressure vessels each year, so Duane understands the documentation involved.
Support the Nashville Section, come join us in-person for a great night of welding education and fellowship. If you absolutely can’t attend in-person, we will attempt to have a hybrid option.
Professional Development Hours (PDH) are available for those in attendance. An email address is required so I know where to send the certificates.
I hope to see you there.
Curtis Duncan
AWS Nashville Section Chair
RSVP by sending your name and intent, plus contact information if you like to nashville@awssections.org
TCAT Portland (Nashville Satellite), 602 S Broadway, Portland, TN 37148
