{"id":446,"date":"2023-03-10T22:10:11","date_gmt":"2023-03-10T22:10:11","guid":{"rendered":"https:\/\/sections.aws.org\/central-louisiana\/?p=446"},"modified":"2023-03-17T13:08:28","modified_gmt":"2023-03-17T13:08:28","slug":"%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck","status":"publish","type":"post","link":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/","title":{"rendered":"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck!"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"446\" class=\"elementor elementor-446\" data-elementor-post-type=\"post\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-6f7dd3b elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"6f7dd3b\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-b2e91da\" data-id=\"b2e91da\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-97cd638 elementor-widget elementor-widget-text-editor\" data-id=\"97cd638\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div id=\"section_1678485728970\" class=\"hse-section\">\n<div class=\"hse-column-container\">\n<div id=\"column_1678485728970_0\" class=\"hse-column hse-size-6\">\n<div id=\"hs_cos_wrapper_module_16784857485004\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<table class=\"hse-image-wrapper\" role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td align=\"center\" valign=\"top\"><a href=\"https:\/\/awssection.com\/batonrouge\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\"><img decoding=\"async\" src=\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png\" alt=\"09-086-BATON ROUGE-Email Header\" width=\"260\" align=\"middle\" \/><\/a><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<div id=\"column_1678485728970_1\" class=\"hse-column hse-size-6\">\n<div id=\"hs_cos_wrapper_module_16784857454983\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<table class=\"hse-image-wrapper\" role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td align=\"center\" valign=\"top\"><a href=\"https:\/\/awssection.com\/central-louisiana\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\"><img decoding=\"async\" src=\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-509-CENTRAL%20LOUISIANA-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-509-CENTRAL%20LOUISIANA-Email%20Header.png\" alt=\"09-509-CENTRAL LOUISIANA-Email Header\" width=\"260\" align=\"middle\" \/><\/a><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<\/div>\n<\/div>\n<div id=\"section_1678485735697\" class=\"hse-section\">\n<div class=\"hse-column-container\">\n<div id=\"column_1678485735697_0\" class=\"hse-column hse-size-6\">\n<div id=\"hs_cos_wrapper_module_16784857426382\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<table class=\"hse-image-wrapper\" role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td align=\"center\" valign=\"top\"><a href=\"https:\/\/awssection.com\/acadiana\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\"><img decoding=\"async\" src=\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-148-ACADIANA-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-148-ACADIANA-Email%20Header.png\" alt=\"09-148-ACADIANA-Email Header\" width=\"260\" align=\"middle\" \/><\/a><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<div id=\"column_1678485735697_1\" class=\"hse-column hse-size-6\">\n<div id=\"hs_cos_wrapper_module_16784857396931\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<table class=\"hse-image-wrapper\" role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td align=\"center\" valign=\"top\"><a href=\"https:\/\/awssection.com\/morgancity\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\"><img decoding=\"async\" src=\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-108-MORGAN%20CITY-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-108-MORGAN%20CITY-Email%20Header.png\" alt=\"09-108-MORGAN CITY-Email Header\" width=\"260\" align=\"middle\" \/><\/a><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<\/div>\n<\/div>\n<div id=\"section-2\" class=\"hse-section\">\n<div class=\"hse-column-container\">\n<div id=\"column-2-1\" class=\"hse-column hse-size-12\">\n<table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td class=\"hs_padded\">\n<div id=\"hs_cos_wrapper_module_16123705719201\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<div id=\"hs_cos_wrapper_module_16123705719201_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\">\n<h1 align=\"center\"><strong>AWS Joint Section President&#8217;s Visit<\/strong><\/h1>\n<h1 align=\"center\"><strong>at Crawfish Town USA<\/strong><\/h1>\n<h3 align=\"center\"><strong>Wednesday, March 22<sup>nd\u00a0<\/sup>&#8211; 6:00 PM<\/strong><\/h3>\n<p align=\"center\">Crawfish Town USA &#8211; Henderson, LA<\/p>\n\n<\/div>\n<\/div><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<\/div>\n<div id=\"module_1662757920637\" class=\"hse-section\">\n<div class=\"hse-column-container\">\n<div id=\"module_1662757920637_0\" class=\"hse-column hse-size-12\">\n<table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td class=\"hs_padded\">\n<div id=\"hs_cos_wrapper_module_16627579206113\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<div id=\"hs_cos_wrapper_module_16627579206113_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\">\n<p align=\"center\">This is a joint section meeting for District 9.<\/p>\n<p align=\"center\">AWS President, Dennis Eck, will be in attendance.<\/p>\n\n<\/div>\n<\/div><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<\/div>\n<div id=\"section_1662757756263\" class=\"hse-section\">\n<div class=\"hse-column-container\">\n<div id=\"column_1662757756263_0\" class=\"hse-column hse-size-12\">\n<table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td class=\"hs_padded\">\n<div id=\"hs_cos_wrapper_module_16627574060561\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><center><a href=\"https:\/\/s3.us-east-1.amazonaws.com\/sections-www.aws.org\/attach\/Crawfish_Town_3-22-2023.pdf\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\">View the Meeting Announcement<\/a><\/center><a href=\"https:\/\/s3.us-east-1.amazonaws.com\/sections-www.aws.org\/attach\/Crawfish_Town_3-22-2023.pdf\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"1\"><img fetchpriority=\"high\" decoding=\"async\" class=\"aligncenter\" src=\"https:\/\/s3.us-east-1.amazonaws.com\/sections-www.aws.org\/attach\/Crawfish_Town_3-22-2023.jpg\" alt=\"AWS Baton Rouge Section hosts Joint Meeting March 2023 Meeting Announcement\" width=\"260\" height=\"360\" \/><\/a>\n\n<\/div><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\">\n<tbody>\n<tr>\n<td class=\"hs_padded\">\n<div id=\"hs_cos_wrapper_module_16341343412791\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\">\n<div id=\"hs_cos_wrapper_module_16341343412791_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\">\n<h3 align=\"center\"><strong>RSVP<\/strong><\/h3>\n<p align=\"center\">FREE for all who RSVP &#8211; $20 for No RSVP\nPlease RSVP by Monday, March 20<sup>th<\/sup>\u00a0to\n<a href=\"mailto:fit@fairbanksinspection.com\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\">fit@fairbanksinspection.com<\/a>\n225-473-6362<\/p>\n\n<\/div>\n<\/div><\/td>\n<\/tr>\n<\/tbody>\n<\/table>\n<\/div>\n<\/div>\n<\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t","protected":false},"excerpt":{"rendered":"<p>AWS Joint Section President&#8217;s Visit at Crawfish Town USA Wednesday, March 22nd\u00a0&#8211; 6:00 PM Crawfish Town USA &#8211; Henderson, LA This is a joint section meeting for District 9. AWS President, Dennis Eck, will be in attendance. View the Meeting Announcement RSVP FREE for all who RSVP &#8211; $20 for No RSVP Please RSVP by&#8230;<\/p>\n<p class=\"more-link\"><a href=\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\"><span>Read More<\/span><i>&#43;<\/i><\/a><\/p>\n","protected":false},"author":4,"featured_media":0,"comment_status":"closed","ping_status":"","sticky":false,"template":"","format":"standard","meta":{"content-type":"","_monsterinsights_skip_tracking":false,"_monsterinsights_sitenote_active":false,"_monsterinsights_sitenote_note":"","_monsterinsights_sitenote_category":0,"footnotes":""},"categories":[7,2],"tags":[],"class_list":["post-446","post","type-post","status-publish","format-standard","hentry","category-announcement","category-meeting-announcement"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v24.3 - https:\/\/yoast.com\/wordpress\/plugins\/seo\/ -->\n<title>?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck! - AWS Central Louisiana Section<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/\ud83d\udc4bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\" \/>\n<meta property=\"og:locale\" content=\"en_US\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck! - AWS Central Louisiana Section\" \/>\n<meta property=\"og:description\" content=\"AWS Joint Section President&#8217;s Visit at Crawfish Town USA Wednesday, March 22nd\u00a0&#8211; 6:00 PM Crawfish Town USA &#8211; Henderson, LA This is a joint section meeting for District 9. AWS President, Dennis Eck, will be in attendance. View the Meeting Announcement RSVP FREE for all who RSVP &#8211; $20 for No RSVP Please RSVP by&#8230;Read More&#043;\" \/>\n<meta property=\"og:url\" content=\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/\ud83d\udc4bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\" \/>\n<meta property=\"og:site_name\" content=\"AWS Central Louisiana Section\" \/>\n<meta property=\"article:published_time\" content=\"2023-03-10T22:10:11+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2023-03-17T13:08:28+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png\" \/>\n<meta name=\"author\" content=\"dgaschler\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<meta name=\"twitter:label1\" content=\"Written by\" \/>\n\t<meta name=\"twitter:data1\" content=\"dgaschler\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\/\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#article\",\"isPartOf\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\"},\"author\":{\"name\":\"dgaschler\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5\"},\"headline\":\"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck!\",\"datePublished\":\"2023-03-10T22:10:11+00:00\",\"dateModified\":\"2023-03-17T13:08:28+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\"},\"wordCount\":71,\"publisher\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#organization\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png\",\"articleSection\":[\"Announcement\",\"Meeting Announcement\"],\"inLanguage\":\"en-US\"},{\"@type\":\"WebPage\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\",\"url\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\",\"name\":\"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck! - AWS Central Louisiana Section\",\"isPartOf\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png\",\"datePublished\":\"2023-03-10T22:10:11+00:00\",\"dateModified\":\"2023-03-17T13:08:28+00:00\",\"breadcrumb\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#breadcrumb\"},\"inLanguage\":\"en-US\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage\",\"url\":\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png\",\"contentUrl\":\"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"Home\",\"item\":\"https:\/\/sections.aws.org\/central-louisiana\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck!\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#website\",\"url\":\"https:\/\/sections.aws.org\/central-louisiana\/\",\"name\":\"AWS Central Louisiana Section\",\"description\":\"District 9 - Section 509\",\"publisher\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\/\/sections.aws.org\/central-louisiana\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"en-US\"},{\"@type\":\"Organization\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#organization\",\"name\":\"AWS Central Louisiana Section\",\"url\":\"https:\/\/sections.aws.org\/central-louisiana\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/logo\/image\/\",\"url\":\"https:\/\/sections.aws.org\/central-louisiana\/wp-content\/uploads\/sites\/56\/2024\/02\/awslogo-sectionsPage-l.png\",\"contentUrl\":\"https:\/\/sections.aws.org\/central-louisiana\/wp-content\/uploads\/sites\/56\/2024\/02\/awslogo-sectionsPage-l.png\",\"width\":200,\"height\":200,\"caption\":\"AWS Central Louisiana Section\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/logo\/image\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5\",\"name\":\"dgaschler\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/person\/image\/\",\"url\":\"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g\",\"contentUrl\":\"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g\",\"caption\":\"dgaschler\"},\"description\":\"Membership\",\"url\":\"https:\/\/sections.aws.org\/central-louisiana\/author\/dgaschler\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck! - AWS Central Louisiana Section","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/\ud83d\udc4bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/","og_locale":"en_US","og_type":"article","og_title":"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck! - AWS Central Louisiana Section","og_description":"AWS Joint Section President&#8217;s Visit at Crawfish Town USA Wednesday, March 22nd\u00a0&#8211; 6:00 PM Crawfish Town USA &#8211; Henderson, LA This is a joint section meeting for District 9. AWS President, Dennis Eck, will be in attendance. View the Meeting Announcement RSVP FREE for all who RSVP &#8211; $20 for No RSVP Please RSVP by&#8230;Read More&#43;","og_url":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/\ud83d\udc4bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/","og_site_name":"AWS Central Louisiana Section","article_published_time":"2023-03-10T22:10:11+00:00","article_modified_time":"2023-03-17T13:08:28+00:00","og_image":[{"url":"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png","type":"","width":"","height":""}],"author":"dgaschler","twitter_card":"summary_large_image","twitter_misc":{"Written by":"dgaschler"},"schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#article","isPartOf":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/"},"author":{"name":"dgaschler","@id":"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5"},"headline":"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck!","datePublished":"2023-03-10T22:10:11+00:00","dateModified":"2023-03-17T13:08:28+00:00","mainEntityOfPage":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/"},"wordCount":71,"publisher":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/#organization"},"image":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage"},"thumbnailUrl":"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png","articleSection":["Announcement","Meeting Announcement"],"inLanguage":"en-US"},{"@type":"WebPage","@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/","url":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/","name":"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck! - AWS Central Louisiana Section","isPartOf":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/#website"},"primaryImageOfPage":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage"},"image":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage"},"thumbnailUrl":"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png","datePublished":"2023-03-10T22:10:11+00:00","dateModified":"2023-03-17T13:08:28+00:00","breadcrumb":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#breadcrumb"},"inLanguage":"en-US","potentialAction":[{"@type":"ReadAction","target":["https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/"]}]},{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#primaryimage","url":"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png","contentUrl":"https:\/\/7723471.fs1.hubspotusercontent-na1.net\/hub\/7723471\/hubfs\/09-086-BATON%20ROUGE-Email%20Header.png?width=520&amp;upscale=true&amp;name=09-086-BATON%20ROUGE-Email%20Header.png"},{"@type":"BreadcrumbList","@id":"https:\/\/sections.aws.org\/central-louisiana\/2023\/03\/10\/%f0%9f%91%8bjoin-us-3-22-as-we-welcome-2023-aws-president-dennis-eck\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"Home","item":"https:\/\/sections.aws.org\/central-louisiana\/"},{"@type":"ListItem","position":2,"name":"?Join Us 3\/22 as we welcome 2023 AWS President Dennis Eck!"}]},{"@type":"WebSite","@id":"https:\/\/sections.aws.org\/central-louisiana\/#website","url":"https:\/\/sections.aws.org\/central-louisiana\/","name":"AWS Central Louisiana Section","description":"District 9 - Section 509","publisher":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/sections.aws.org\/central-louisiana\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"en-US"},{"@type":"Organization","@id":"https:\/\/sections.aws.org\/central-louisiana\/#organization","name":"AWS Central Louisiana Section","url":"https:\/\/sections.aws.org\/central-louisiana\/","logo":{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/logo\/image\/","url":"https:\/\/sections.aws.org\/central-louisiana\/wp-content\/uploads\/sites\/56\/2024\/02\/awslogo-sectionsPage-l.png","contentUrl":"https:\/\/sections.aws.org\/central-louisiana\/wp-content\/uploads\/sites\/56\/2024\/02\/awslogo-sectionsPage-l.png","width":200,"height":200,"caption":"AWS Central Louisiana Section"},"image":{"@id":"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5","name":"dgaschler","image":{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/central-louisiana\/#\/schema\/person\/image\/","url":"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g","caption":"dgaschler"},"description":"Membership","url":"https:\/\/sections.aws.org\/central-louisiana\/author\/dgaschler\/"}]}},"rttpg_featured_image_url":null,"rttpg_author":{"display_name":"dgaschler","author_link":"https:\/\/sections.aws.org\/central-louisiana\/author\/dgaschler\/"},"rttpg_comment":0,"rttpg_category":"<a href=\"https:\/\/sections.aws.org\/central-louisiana\/category\/announcement\/\" rel=\"category tag\">Announcement<\/a> <a href=\"https:\/\/sections.aws.org\/central-louisiana\/category\/meeting-announcement\/\" rel=\"category tag\">Meeting Announcement<\/a>","rttpg_excerpt":"AWS Joint Section President&#8217;s Visit at Crawfish Town USA Wednesday, March 22nd\u00a0&#8211; 6:00 PM Crawfish Town USA &#8211; Henderson, LA This is a joint section meeting for District 9. AWS President, Dennis Eck, will be in attendance. View the Meeting Announcement RSVP FREE for all who RSVP &#8211; $20 for No RSVP Please RSVP by&#8230;Read&hellip;","_links":{"self":[{"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/posts\/446","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/users\/4"}],"replies":[{"embeddable":true,"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/comments?post=446"}],"version-history":[{"count":9,"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/posts\/446\/revisions"}],"predecessor-version":[{"id":456,"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/posts\/446\/revisions\/456"}],"wp:attachment":[{"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/media?parent=446"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/categories?post=446"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/sections.aws.org\/central-louisiana\/wp-json\/wp\/v2\/tags?post=446"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
