{"id":1129,"date":"2023-08-01T13:44:03","date_gmt":"2023-08-01T13:44:03","guid":{"rendered":"https:\/\/sections.aws.org\/atlanta\/?p=1129"},"modified":"2023-08-01T13:49:25","modified_gmt":"2023-08-01T13:49:25","slug":"%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab","status":"publish","type":"post","link":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/","title":{"rendered":"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d?"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"1129\" class=\"elementor elementor-1129\" data-elementor-post-type=\"post\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-efdf686 elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"efdf686\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-a86a023\" data-id=\"a86a023\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-1259265 elementor-widget elementor-widget-text-editor\" data-id=\"1259265\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div id=\"section-1\" class=\"hse-section\"><div class=\"hse-column-container\"><div id=\"column-1-1\" class=\"hse-column hse-size-12\"><div id=\"hs_cos_wrapper_module-1-1-1\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><table class=\"hse-image-wrapper\" role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td align=\"center\" valign=\"top\"><a href=\"https:\/\/awssection.com\/atlanta\/?utm_campaign=Section%20Communications&amp;utm_source=hs_email&amp;utm_medium=email&amp;_hsenc=p2ANqtz--gGlkd8jnDezfe--3c9HBVnfJqLBXlO0CPqTptZk9TpevAaqPQ-uylZx9bmohRSKi6s21g\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\"><img decoding=\"async\" src=\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\" alt=\"AWS Atlanta Section\" width=\"600\" align=\"middle\" \/><\/a><\/td><\/tr><\/tbody><\/table><\/div><\/div><\/div><\/div><div id=\"section-2\" class=\"hse-section\"><div class=\"hse-column-container\"><div id=\"column-2-1\" class=\"hse-column hse-size-12\"><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module-2-1-1\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><h2 align=\"center\"><strong>Atlanta Section<\/strong><\/h2><h2 align=\"center\"><strong>Technical Meeting: Ben Baldwin<\/strong><\/h2><h1 align=\"center\">\u00a0<\/h1><p id=\"hs_cos_wrapper_module-2-1-1_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" style=\"text-align: center\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><strong>Thursday, August 24<sup>th<\/sup>\u00a0&#8211; 11:00 AM<\/strong><\/p><p class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" style=\"text-align: center\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><span style=\"color: #808080\">McKenny Mechanical Services &#8211; Atlanta, GA<\/span><\/p><\/div><\/td><\/tr><\/tbody><\/table><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16354230888751\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><p id=\"hs_cos_wrapper_module_16354230888751_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" style=\"text-align: center\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><span style=\"color: #000000\">PRESENTER &#8211;\u00a0 BEN BALDWIN \u00a0<\/span><\/p><p data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\">\u00a0<\/p><p class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" style=\"text-align: center\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><span style=\"color: #000000\">This technical meeting will discuss topics of production fabrication and pipe welding assemblies. <\/span><\/p><p class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" style=\"text-align: center\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><span style=\"color: #000000\">Ben will discuss proper procedures for joint preparation. <\/span><\/p><p data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\">\u00a0<\/p><p class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" style=\"text-align: center\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><span style=\"color: #000000\">A tour of shop will be provided. HR rep will be available for employment questions. Pizza and soft drinks will be provided.<\/span><\/p><\/div><\/td><\/tr><\/tbody><\/table><\/div><\/div><\/div><div id=\"section_1635423346691\" class=\"hse-section\"><div class=\"hse-column-container\"><div id=\"column_1635423346691_0\" class=\"hse-column hse-size-12\"><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16354233538683\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16354233538683_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h3 align=\"center\"><strong>Date &amp; Time<\/strong><\/h3><p align=\"center\">Thursday, August 24<sup>th<\/sup>\u00a0<\/p><p align=\"center\">11:00 AM &#8211; 2:00 PM<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16354233511232\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16354233511232_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h3 align=\"center\"><strong>Location<\/strong><\/h3><p align=\"center\">McKenny Mechanical Services<\/p><p align=\"center\">1056 Moreland Industrial Blvd SE \u00a0<\/p><p align=\"center\">Atlanta GA 30316<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16802955938581\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16802955938581_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h3 align=\"center\"><strong>RSVP<\/strong><\/h3><p align=\"center\">RSVP to\u00a0<a href=\"mailto:emsmachine@aol.com\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\">emsmachine@aol.com<\/a>\u00a0NLT 8\/20 for head count on food<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><\/div><\/div><\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t","protected":false},"excerpt":{"rendered":"<p>Atlanta Section Technical Meeting: Ben Baldwin \u00a0 Thursday, August 24th\u00a0&#8211; 11:00 AM McKenny Mechanical Services &#8211; Atlanta, GA PRESENTER &#8211;\u00a0 BEN BALDWIN \u00a0 \u00a0 This technical meeting will discuss topics of production fabrication and pipe welding assemblies. Ben will discuss proper procedures for joint preparation. \u00a0 A tour of shop will be provided. HR rep&#8230;<\/p>\n<p class=\"more-link\"><a href=\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/\"><span>Read More<\/span><i>&#43;<\/i><\/a><\/p>\n","protected":false},"author":27,"featured_media":0,"comment_status":"closed","ping_status":"","sticky":false,"template":"","format":"standard","meta":{"content-type":"","_monsterinsights_skip_tracking":false,"_monsterinsights_sitenote_active":false,"_monsterinsights_sitenote_note":"","_monsterinsights_sitenote_category":0,"footnotes":""},"categories":[7,9],"tags":[],"class_list":["post-1129","post","type-post","status-publish","format-standard","hentry","category-announcement","category-meeting-notice"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v24.3 - https:\/\/yoast.com\/wordpress\/plugins\/seo\/ -->\n<title>?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d? - AWS Atlanta Section<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/\ud83d\udc4bjoin-us-8-24-for-atlanta-section-technical-meeting\ud83d\udc68\ud83c\udfeb\/\" \/>\n<meta property=\"og:locale\" content=\"en_US\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d? - AWS Atlanta Section\" \/>\n<meta property=\"og:description\" content=\"Atlanta Section Technical Meeting: Ben Baldwin \u00a0 Thursday, August 24th\u00a0&#8211; 11:00 AM McKenny Mechanical Services &#8211; Atlanta, GA PRESENTER &#8211;\u00a0 BEN BALDWIN \u00a0 \u00a0 This technical meeting will discuss topics of production fabrication and pipe welding assemblies. Ben will discuss proper procedures for joint preparation. \u00a0 A tour of shop will be provided. HR rep&#8230;Read More&#043;\" \/>\n<meta property=\"og:url\" content=\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/\ud83d\udc4bjoin-us-8-24-for-atlanta-section-technical-meeting\ud83d\udc68\ud83c\udfeb\/\" \/>\n<meta property=\"og:site_name\" content=\"AWS Atlanta Section\" \/>\n<meta property=\"article:published_time\" content=\"2023-08-01T13:44:03+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2023-08-01T13:49:25+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<meta name=\"twitter:label1\" content=\"Written by\" \/>\n\t<meta name=\"twitter:data1\" content=\"\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\/\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#article\",\"isPartOf\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/\"},\"author\":{\"name\":\"\",\"@id\":\"\"},\"headline\":\"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d?\",\"datePublished\":\"2023-08-01T13:44:03+00:00\",\"dateModified\":\"2023-08-01T13:49:25+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/\"},\"wordCount\":102,\"publisher\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#organization\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\",\"articleSection\":[\"Announcement\",\"Meeting Notice\"],\"inLanguage\":\"en-US\"},{\"@type\":\"WebPage\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/\",\"name\":\"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d? - AWS Atlanta Section\",\"isPartOf\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\",\"datePublished\":\"2023-08-01T13:44:03+00:00\",\"dateModified\":\"2023-08-01T13:49:25+00:00\",\"breadcrumb\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#breadcrumb\"},\"inLanguage\":\"en-US\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage\",\"url\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\",\"contentUrl\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"Home\",\"item\":\"https:\/\/sections.aws.org\/atlanta\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d?\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#website\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/\",\"name\":\"AWS Atlanta Section\",\"description\":\"AWS Atlanta Section\",\"publisher\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\/\/sections.aws.org\/atlanta\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"en-US\"},{\"@type\":\"Organization\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#organization\",\"name\":\"AWS Atlanta Section\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png\",\"contentUrl\":\"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png\",\"width\":200,\"height\":200,\"caption\":\"AWS Atlanta Section\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/\"}},{\"@type\":\"Person\",\"@id\":\"\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/author\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d? - AWS Atlanta Section","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/\ud83d\udc4bjoin-us-8-24-for-atlanta-section-technical-meeting\ud83d\udc68\ud83c\udfeb\/","og_locale":"en_US","og_type":"article","og_title":"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d? - AWS Atlanta Section","og_description":"Atlanta Section Technical Meeting: Ben Baldwin \u00a0 Thursday, August 24th\u00a0&#8211; 11:00 AM McKenny Mechanical Services &#8211; Atlanta, GA PRESENTER &#8211;\u00a0 BEN BALDWIN \u00a0 \u00a0 This technical meeting will discuss topics of production fabrication and pipe welding assemblies. Ben will discuss proper procedures for joint preparation. \u00a0 A tour of shop will be provided. HR rep&#8230;Read More&#43;","og_url":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/\ud83d\udc4bjoin-us-8-24-for-atlanta-section-technical-meeting\ud83d\udc68\ud83c\udfeb\/","og_site_name":"AWS Atlanta Section","article_published_time":"2023-08-01T13:44:03+00:00","article_modified_time":"2023-08-01T13:49:25+00:00","og_image":[{"url":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","type":"","width":"","height":""}],"twitter_card":"summary_large_image","twitter_misc":{"Written by":""},"schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#article","isPartOf":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/"},"author":{"name":"","@id":""},"headline":"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d?","datePublished":"2023-08-01T13:44:03+00:00","dateModified":"2023-08-01T13:49:25+00:00","mainEntityOfPage":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/"},"wordCount":102,"publisher":{"@id":"https:\/\/sections.aws.org\/atlanta\/#organization"},"image":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage"},"thumbnailUrl":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","articleSection":["Announcement","Meeting Notice"],"inLanguage":"en-US"},{"@type":"WebPage","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/","url":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/","name":"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d? - AWS Atlanta Section","isPartOf":{"@id":"https:\/\/sections.aws.org\/atlanta\/#website"},"primaryImageOfPage":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage"},"image":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage"},"thumbnailUrl":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","datePublished":"2023-08-01T13:44:03+00:00","dateModified":"2023-08-01T13:49:25+00:00","breadcrumb":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#breadcrumb"},"inLanguage":"en-US","potentialAction":[{"@type":"ReadAction","target":["https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/"]}]},{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#primaryimage","url":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","contentUrl":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png"},{"@type":"BreadcrumbList","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/08\/01\/%f0%9f%91%8bjoin-us-8-24-for-atlanta-section-technical-meeting%f0%9f%91%a8%f0%9f%8f%ab\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"Home","item":"https:\/\/sections.aws.org\/atlanta\/"},{"@type":"ListItem","position":2,"name":"?Join Us 8\/24 for Atlanta Section Technical Meeting?\u200d?"}]},{"@type":"WebSite","@id":"https:\/\/sections.aws.org\/atlanta\/#website","url":"https:\/\/sections.aws.org\/atlanta\/","name":"AWS Atlanta Section","description":"AWS Atlanta Section","publisher":{"@id":"https:\/\/sections.aws.org\/atlanta\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/sections.aws.org\/atlanta\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"en-US"},{"@type":"Organization","@id":"https:\/\/sections.aws.org\/atlanta\/#organization","name":"AWS Atlanta Section","url":"https:\/\/sections.aws.org\/atlanta\/","logo":{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/","url":"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png","contentUrl":"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png","width":200,"height":200,"caption":"AWS Atlanta Section"},"image":{"@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"","url":"https:\/\/sections.aws.org\/atlanta\/author\/"}]}},"rttpg_featured_image_url":null,"rttpg_author":{"display_name":"","author_link":"https:\/\/sections.aws.org\/atlanta\/author\/"},"rttpg_comment":0,"rttpg_category":"<a href=\"https:\/\/sections.aws.org\/atlanta\/category\/announcement\/\" rel=\"category tag\">Announcement<\/a> <a href=\"https:\/\/sections.aws.org\/atlanta\/category\/meeting-notice\/\" rel=\"category tag\">Meeting Notice<\/a>","rttpg_excerpt":"Atlanta Section Technical Meeting: Ben Baldwin \u00a0 Thursday, August 24th\u00a0&#8211; 11:00 AM McKenny Mechanical Services &#8211; Atlanta, GA PRESENTER &#8211;\u00a0 BEN BALDWIN \u00a0 \u00a0 This technical meeting will discuss topics of production fabrication and pipe welding assemblies. Ben will discuss proper procedures for joint preparation. \u00a0 A tour of shop will be provided. HR rep&#8230;Read&hellip;","_links":{"self":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts\/1129","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/users\/27"}],"replies":[{"embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/comments?post=1129"}],"version-history":[{"count":4,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts\/1129\/revisions"}],"predecessor-version":[{"id":1133,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts\/1129\/revisions\/1133"}],"wp:attachment":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/media?parent=1129"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/categories?post=1129"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/tags?post=1129"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
