{"id":1090,"date":"2023-03-31T21:01:53","date_gmt":"2023-03-31T21:01:53","guid":{"rendered":"https:\/\/sections.aws.org\/atlanta\/?p=1090"},"modified":"2023-03-31T21:03:01","modified_gmt":"2023-03-31T21:03:01","slug":"%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum","status":"publish","type":"post","link":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/","title":{"rendered":"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &#038; alum"},"content":{"rendered":"\t\t<div data-elementor-type=\"wp-post\" data-elementor-id=\"1090\" class=\"elementor elementor-1090\" data-elementor-post-type=\"post\">\n\t\t\t\t\t\t<section class=\"elementor-section elementor-top-section elementor-element elementor-element-360c57e elementor-section-boxed elementor-section-height-default elementor-section-height-default\" data-id=\"360c57e\" data-element_type=\"section\" data-e-type=\"section\">\n\t\t\t\t\t\t<div class=\"elementor-container elementor-column-gap-default\">\n\t\t\t\t\t<div class=\"elementor-column elementor-col-100 elementor-top-column elementor-element elementor-element-fa0b364\" data-id=\"fa0b364\" data-element_type=\"column\" data-e-type=\"column\">\n\t\t\t<div class=\"elementor-widget-wrap elementor-element-populated\">\n\t\t\t\t\t\t<div class=\"elementor-element elementor-element-bd6628c elementor-widget elementor-widget-text-editor\" data-id=\"bd6628c\" data-element_type=\"widget\" data-e-type=\"widget\" data-widget_type=\"text-editor.default\">\n\t\t\t\t<div class=\"elementor-widget-container\">\n\t\t\t\t\t\t\t\t\t<div id=\"section-1\" class=\"hse-section\"><div class=\"hse-column-container\"><div id=\"column-1-1\" class=\"hse-column hse-size-12\"><div id=\"hs_cos_wrapper_module-1-1-1\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><table class=\"hse-image-wrapper\" role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td align=\"center\" valign=\"top\"><a href=\"https:\/\/awssection.com\/atlanta\/?utm_campaign=Section%20Communications&amp;utm_source=hs_email&amp;utm_medium=email&amp;_hsenc=p2ANqtz-8Yzb9VEByCu5F_nYyAEr30q3ZlwkcI7Orc_-FA-ELnt3Wy9hLE_-J2009AMZslIFFznjgi\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\"><img decoding=\"async\" src=\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\" alt=\"AWS Atlanta Section\" width=\"600\" align=\"middle\" \/><\/a><\/td><\/tr><\/tbody><\/table><\/div><\/div><\/div><\/div><div id=\"section-2\" class=\"hse-section\"><div class=\"hse-column-container\"><div id=\"column-2-1\" class=\"hse-column hse-size-12\"><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module-2-1-1\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module-2-1-1_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h1 align=\"center\"><strong>Atlanta Section Technical Meeting: GTAW<\/strong><\/h1><h1 align=\"center\">\u00a0<\/h1><h3 align=\"center\"><strong>Thursday, April 20<sup>th<\/sup>\u00a0&#8211; 5:30 PM<\/strong><\/h3><p align=\"center\">Miller Training Center &#8211; Lawrenceville, GA<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16354230888751\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16354230888751_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><p style=\"text-align: left;\">Food &amp; soft drinks will be provided by MILLER.<br \/>TOPIC: GTAW intermediate and advance parameters on thin S\/S &amp; alum. materials. Andrew will also go over myths and best practices for shielding gases . live demonstrations will follow lecture . \u00a0(25 person capacity ) 1st come 1st serve<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><\/div><\/div><\/div><div id=\"section_1635423346691\" class=\"hse-section\"><div class=\"hse-column-container\"><div id=\"column_1635423346691_0\" class=\"hse-column hse-size-12\"><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16354233538683\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16354233538683_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h3 align=\"center\"><strong>Date &amp; Time<\/strong><\/h3><p align=\"center\">Thursday, April 20<sup>th<\/sup>\u00a0<br \/>5:30 &#8211; 9:00 PM<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16354233511232\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16354233511232_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h3 align=\"center\"><strong>Location<\/strong><\/h3><p align=\"center\">Miller Training Center<br \/>1655 Lakes Pkwy<br \/>Lawrenceville, GA<\/p><\/div><\/div><\/td><\/tr><\/tbody><\/table><table role=\"presentation\" width=\"100%\" cellspacing=\"0\" cellpadding=\"0\"><tbody><tr><td class=\"hs_padded\"><div id=\"hs_cos_wrapper_module_16802955938581\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_module\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"module\"><div id=\"hs_cos_wrapper_module_16802955938581_\" class=\"hs_cos_wrapper hs_cos_wrapper_widget hs_cos_wrapper_type_rich_text\" data-hs-cos-general-type=\"widget\" data-hs-cos-type=\"rich_text\"><h3 align=\"center\"><strong>RSVP<\/strong><\/h3><div align=\"center\">RSVP to\u00a0<a href=\"mailto:emsmachine@aol.com\" target=\"_blank\" rel=\"noopener\" data-hs-link-id=\"0\">emsmachine@aol.com<\/a>\u00a0for head count for dinner<\/div><\/div><\/div><\/td><\/tr><\/tbody><\/table><\/div><\/div><\/div>\t\t\t\t\t\t\t\t<\/div>\n\t\t\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/div>\n\t\t\t\t\t<\/div>\n\t\t<\/section>\n\t\t\t\t<\/div>\n\t\t","protected":false},"excerpt":{"rendered":"<p>Atlanta Section Technical Meeting: GTAW \u00a0 Thursday, April 20th\u00a0&#8211; 5:30 PM Miller Training Center &#8211; Lawrenceville, GA Food &amp; soft drinks will be provided by MILLER.TOPIC: GTAW intermediate and advance parameters on thin S\/S &amp; alum. materials. Andrew will also go over myths and best practices for shielding gases . live demonstrations will follow lecture&#8230;<\/p>\n<p class=\"more-link\"><a href=\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\"><span>Read More<\/span><i>&#43;<\/i><\/a><\/p>\n","protected":false},"author":4,"featured_media":0,"comment_status":"closed","ping_status":"closed","sticky":false,"template":"","format":"standard","meta":{"content-type":"","_monsterinsights_skip_tracking":false,"_monsterinsights_sitenote_active":false,"_monsterinsights_sitenote_note":"","_monsterinsights_sitenote_category":0,"footnotes":""},"categories":[7,6,9],"tags":[],"class_list":["post-1090","post","type-post","status-publish","format-standard","hentry","category-announcement","category-meeting-announcement","category-meeting-notice"],"yoast_head":"<!-- This site is optimized with the Yoast SEO plugin v24.3 - https:\/\/yoast.com\/wordpress\/plugins\/seo\/ -->\n<title>?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &amp; alum - AWS Atlanta Section<\/title>\n<meta name=\"robots\" content=\"index, follow, max-snippet:-1, max-image-preview:large, max-video-preview:-1\" \/>\n<link rel=\"canonical\" href=\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/\ud83d\udc4bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\" \/>\n<meta property=\"og:locale\" content=\"en_US\" \/>\n<meta property=\"og:type\" content=\"article\" \/>\n<meta property=\"og:title\" content=\"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &amp; alum - AWS Atlanta Section\" \/>\n<meta property=\"og:description\" content=\"Atlanta Section Technical Meeting: GTAW \u00a0 Thursday, April 20th\u00a0&#8211; 5:30 PM Miller Training Center &#8211; Lawrenceville, GA Food &amp; soft drinks will be provided by MILLER.TOPIC: GTAW intermediate and advance parameters on thin S\/S &amp; alum. materials. Andrew will also go over myths and best practices for shielding gases . live demonstrations will follow lecture&#8230;Read More&#043;\" \/>\n<meta property=\"og:url\" content=\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/\ud83d\udc4bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\" \/>\n<meta property=\"og:site_name\" content=\"AWS Atlanta Section\" \/>\n<meta property=\"article:published_time\" content=\"2023-03-31T21:01:53+00:00\" \/>\n<meta property=\"article:modified_time\" content=\"2023-03-31T21:03:01+00:00\" \/>\n<meta property=\"og:image\" content=\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\" \/>\n<meta name=\"author\" content=\"dgaschler\" \/>\n<meta name=\"twitter:card\" content=\"summary_large_image\" \/>\n<meta name=\"twitter:label1\" content=\"Written by\" \/>\n\t<meta name=\"twitter:data1\" content=\"dgaschler\" \/>\n<script type=\"application\/ld+json\" class=\"yoast-schema-graph\">{\"@context\":\"https:\/\/schema.org\",\"@graph\":[{\"@type\":\"Article\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#article\",\"isPartOf\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\"},\"author\":{\"name\":\"dgaschler\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5\"},\"headline\":\"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &#038; alum\",\"datePublished\":\"2023-03-31T21:01:53+00:00\",\"dateModified\":\"2023-03-31T21:03:01+00:00\",\"mainEntityOfPage\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\"},\"wordCount\":99,\"publisher\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#organization\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\",\"articleSection\":[\"Announcement\",\"Meeting Announcement\",\"Meeting Notice\"],\"inLanguage\":\"en-US\"},{\"@type\":\"WebPage\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\",\"name\":\"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S & alum - AWS Atlanta Section\",\"isPartOf\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#website\"},\"primaryImageOfPage\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage\"},\"thumbnailUrl\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\",\"datePublished\":\"2023-03-31T21:01:53+00:00\",\"dateModified\":\"2023-03-31T21:03:01+00:00\",\"breadcrumb\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#breadcrumb\"},\"inLanguage\":\"en-US\",\"potentialAction\":[{\"@type\":\"ReadAction\",\"target\":[\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/\"]}]},{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage\",\"url\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\",\"contentUrl\":\"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png\"},{\"@type\":\"BreadcrumbList\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#breadcrumb\",\"itemListElement\":[{\"@type\":\"ListItem\",\"position\":1,\"name\":\"Home\",\"item\":\"https:\/\/sections.aws.org\/atlanta\/\"},{\"@type\":\"ListItem\",\"position\":2,\"name\":\"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &#038; alum\"}]},{\"@type\":\"WebSite\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#website\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/\",\"name\":\"AWS Atlanta Section\",\"description\":\"AWS Atlanta Section\",\"publisher\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#organization\"},\"potentialAction\":[{\"@type\":\"SearchAction\",\"target\":{\"@type\":\"EntryPoint\",\"urlTemplate\":\"https:\/\/sections.aws.org\/atlanta\/?s={search_term_string}\"},\"query-input\":{\"@type\":\"PropertyValueSpecification\",\"valueRequired\":true,\"valueName\":\"search_term_string\"}}],\"inLanguage\":\"en-US\"},{\"@type\":\"Organization\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#organization\",\"name\":\"AWS Atlanta Section\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/\",\"logo\":{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png\",\"contentUrl\":\"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png\",\"width\":200,\"height\":200,\"caption\":\"AWS Atlanta Section\"},\"image\":{\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/\"}},{\"@type\":\"Person\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5\",\"name\":\"dgaschler\",\"image\":{\"@type\":\"ImageObject\",\"inLanguage\":\"en-US\",\"@id\":\"https:\/\/sections.aws.org\/atlanta\/#\/schema\/person\/image\/\",\"url\":\"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g\",\"contentUrl\":\"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g\",\"caption\":\"dgaschler\"},\"description\":\"Membership\",\"url\":\"https:\/\/sections.aws.org\/atlanta\/author\/dgaschler\/\"}]}<\/script>\n<!-- \/ Yoast SEO plugin. -->","yoast_head_json":{"title":"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S & alum - AWS Atlanta Section","robots":{"index":"index","follow":"follow","max-snippet":"max-snippet:-1","max-image-preview":"max-image-preview:large","max-video-preview":"max-video-preview:-1"},"canonical":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/\ud83d\udc4bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/","og_locale":"en_US","og_type":"article","og_title":"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S & alum - AWS Atlanta Section","og_description":"Atlanta Section Technical Meeting: GTAW \u00a0 Thursday, April 20th\u00a0&#8211; 5:30 PM Miller Training Center &#8211; Lawrenceville, GA Food &amp; soft drinks will be provided by MILLER.TOPIC: GTAW intermediate and advance parameters on thin S\/S &amp; alum. materials. Andrew will also go over myths and best practices for shielding gases . live demonstrations will follow lecture&#8230;Read More&#43;","og_url":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/\ud83d\udc4bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/","og_site_name":"AWS Atlanta Section","article_published_time":"2023-03-31T21:01:53+00:00","article_modified_time":"2023-03-31T21:03:01+00:00","og_image":[{"url":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","type":"","width":"","height":""}],"author":"dgaschler","twitter_card":"summary_large_image","twitter_misc":{"Written by":"dgaschler"},"schema":{"@context":"https:\/\/schema.org","@graph":[{"@type":"Article","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#article","isPartOf":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/"},"author":{"name":"dgaschler","@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5"},"headline":"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &#038; alum","datePublished":"2023-03-31T21:01:53+00:00","dateModified":"2023-03-31T21:03:01+00:00","mainEntityOfPage":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/"},"wordCount":99,"publisher":{"@id":"https:\/\/sections.aws.org\/atlanta\/#organization"},"image":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage"},"thumbnailUrl":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","articleSection":["Announcement","Meeting Announcement","Meeting Notice"],"inLanguage":"en-US"},{"@type":"WebPage","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/","url":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/","name":"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S & alum - AWS Atlanta Section","isPartOf":{"@id":"https:\/\/sections.aws.org\/atlanta\/#website"},"primaryImageOfPage":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage"},"image":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage"},"thumbnailUrl":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","datePublished":"2023-03-31T21:01:53+00:00","dateModified":"2023-03-31T21:03:01+00:00","breadcrumb":{"@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#breadcrumb"},"inLanguage":"en-US","potentialAction":[{"@type":"ReadAction","target":["https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/"]}]},{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#primaryimage","url":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png","contentUrl":"https:\/\/cdn2.hubspot.net\/hub\/7723471\/hubfs\/AWS-ATLANTA-Email-Header.png?upscale=true&amp;width=1200&amp;upscale=true&amp;name=AWS-ATLANTA-Email-Header.png"},{"@type":"BreadcrumbList","@id":"https:\/\/sections.aws.org\/atlanta\/2023\/03\/31\/%f0%9f%91%8bjoin-us-4-20-for-technical-meeting-gtaw-parameters-on-thin-s-s-alum\/#breadcrumb","itemListElement":[{"@type":"ListItem","position":1,"name":"Home","item":"https:\/\/sections.aws.org\/atlanta\/"},{"@type":"ListItem","position":2,"name":"?Join Us 4\/20 for Technical Meeting: GTAW parameters on thin S\/S &#038; alum"}]},{"@type":"WebSite","@id":"https:\/\/sections.aws.org\/atlanta\/#website","url":"https:\/\/sections.aws.org\/atlanta\/","name":"AWS Atlanta Section","description":"AWS Atlanta Section","publisher":{"@id":"https:\/\/sections.aws.org\/atlanta\/#organization"},"potentialAction":[{"@type":"SearchAction","target":{"@type":"EntryPoint","urlTemplate":"https:\/\/sections.aws.org\/atlanta\/?s={search_term_string}"},"query-input":{"@type":"PropertyValueSpecification","valueRequired":true,"valueName":"search_term_string"}}],"inLanguage":"en-US"},{"@type":"Organization","@id":"https:\/\/sections.aws.org\/atlanta\/#organization","name":"AWS Atlanta Section","url":"https:\/\/sections.aws.org\/atlanta\/","logo":{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/","url":"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png","contentUrl":"https:\/\/sections.aws.org\/atlanta\/wp-content\/uploads\/sites\/80\/2024\/01\/awslogo-sectionsPage-l.png","width":200,"height":200,"caption":"AWS Atlanta Section"},"image":{"@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/logo\/image\/"}},{"@type":"Person","@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/person\/2af9a98b701e39d0137b3b55ca0d7dc5","name":"dgaschler","image":{"@type":"ImageObject","inLanguage":"en-US","@id":"https:\/\/sections.aws.org\/atlanta\/#\/schema\/person\/image\/","url":"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g","contentUrl":"https:\/\/secure.gravatar.com\/avatar\/b29a28a08fe31cd86b9efa782fd8ce7353b5faa0583120e320ff2a26693a6e4a?s=96&d=mm&r=g","caption":"dgaschler"},"description":"Membership","url":"https:\/\/sections.aws.org\/atlanta\/author\/dgaschler\/"}]}},"rttpg_featured_image_url":null,"rttpg_author":{"display_name":"dgaschler","author_link":"https:\/\/sections.aws.org\/atlanta\/author\/dgaschler\/"},"rttpg_comment":0,"rttpg_category":"<a href=\"https:\/\/sections.aws.org\/atlanta\/category\/announcement\/\" rel=\"category tag\">Announcement<\/a> <a href=\"https:\/\/sections.aws.org\/atlanta\/category\/meeting-announcement\/\" rel=\"category tag\">Meeting Announcement<\/a> <a href=\"https:\/\/sections.aws.org\/atlanta\/category\/meeting-notice\/\" rel=\"category tag\">Meeting Notice<\/a>","rttpg_excerpt":"Atlanta Section Technical Meeting: GTAW \u00a0 Thursday, April 20th\u00a0&#8211; 5:30 PM Miller Training Center &#8211; Lawrenceville, GA Food &amp; soft drinks will be provided by MILLER.TOPIC: GTAW intermediate and advance parameters on thin S\/S &amp; alum. materials. Andrew will also go over myths and best practices for shielding gases . live demonstrations will follow lecture&#8230;Read&hellip;","_links":{"self":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts\/1090","targetHints":{"allow":["GET"]}}],"collection":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts"}],"about":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/types\/post"}],"author":[{"embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/users\/4"}],"replies":[{"embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/comments?post=1090"}],"version-history":[{"count":4,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts\/1090\/revisions"}],"predecessor-version":[{"id":1094,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/posts\/1090\/revisions\/1094"}],"wp:attachment":[{"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/media?parent=1090"}],"wp:term":[{"taxonomy":"category","embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/categories?post=1090"},{"taxonomy":"post_tag","embeddable":true,"href":"https:\/\/sections.aws.org\/atlanta\/wp-json\/wp\/v2\/tags?post=1090"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
